Rear discs question.
I had a new set of discs arrive yesterday.
I noticed that the rear discs are different. The drum part of the new discs is about 10 - 15mm shallower (disc to wheel mounting face) than the discs that are currently on my car.
Will they still fit okay?
Surely the weel will sit further in??
Thanks,
Phil
Thanks,
Phil
Phil
I've got new discs for mine and just checked them and 60mm old ones 70mm:sob:
Just check Black Diamond part and I seem to have the the right ones.
<!--QuoteBegin-wil3086+--><div class='quotetop'>(wil3086)</div><div class='quotemain'><!--QuoteEBegin-->I Had The Same Problem Before And Had To Return Them<!--QuoteEnd--></div><!--QuoteEEnd-->
Oh bugger:frown:
Oh bugger:frown:
The changeover on the rear discs is a right pain and is not very well defined by vauxhall. Basically you need to check the sizes of the discs before buying. Bought mine from wallace a few years back had them all painted up to match the calipers before i fitted them only to find they were incorrrect. Getting that hammerite of was a right pita.
Tim2001
