Smash damage!
Smash damage!
first of all sorry bout the essay!
right then as some of you may have read i now own a v6, bought with the odd prob, one being a wobble when doing anything over 65mph.
after further investigation ive found that it must have been in a smash in earlier life as the rear quarter has been replaced... to cut a long story short ive been measuring under the car and have found that the distance from the front wheels to the back is 10mm larger on the drivers side(bumped side). i have measured from various points under the car and it looks like the rear wheel is pointing out at the front aswell. im really ******* off about it and dont know what to do. when you drive above 65 the car feels very unsteady and as you increase the speed the wobble/vibration is so bad the cd player skips. please excuse my lack of technical knowledge and description, any ideas would be gratefully aprieciated!
ash_pearce
<!--QuoteBegin-ash_pearce+--><div class='quotetop'>(ash_pearce)</div><div class='quotemain'><!--QuoteEBegin-->sorry to be a nob but whats a 'vic' test?<!--QuoteEnd--></div><!--QuoteEEnd-->its a test to check if a crash damaged car has been repaired properly to go back on the road it is done by the ministry of transport
nigescalli
its got worse in the week ive had it, ive drove to and from cardiff twice and i had to stay below 60 on the way back last night. playing around earlier i found that there was a fair amount of play in the mount that holds the subframe to the car. if i was to replace the mount and possibly the subframe or wishbone and that brought the toe in would it really matter if the wheel was further back?
ash_pearce
if its further back on one side it wont be rolling true, so will have the same effect as steering out slightly on one wheel, will be lethal ..... and eat tyres
take it for a couple of LOCAL no obligation quotes then you'll be able to gauge for yourself if your up to doing what it needs, using it for any kind of journey would be madness in that state, and it'll only get worse ...... sorry [img]/sad.gif[/img]
MJ
Users browsing this forum: Google [Bot] and 13 guests
