adjustable rear bushs????????
Chaps i gotta fit some of these rear adjustable trailing arm bush's on my cally t. The only thing is i have no instructions with this kit. I can see how you get them out and in but how do you adjust them?? I've got a bush that is in 2 halfs with an insert and a 4" bolt which has some splines around the collour and then i have 2 bolts for each bush. Sorry but i'm a little confused tbh. Any help would be grand... Cheers
chunkylover
Ok I've fitted these bushs and all sort of went to plan. BUT when i sent the motor of to get the front track sorted out after i lowered it and the rear camber set up, it came back with the steering still out (the other way now) and the camber was apperently correct already, but i only set it by eye!! I find it hard to beleive that i got the camber right on both side setting it by eye but they recon i did.
The thing is now tho that the rear TOE is 55min out on the n/s and 36min out the o/s. I think i'm right in saying that if the rear toe is out the only way to correct it would be to change the rear arms. Does that sound right?
chunkylover
