wheel bearings??
wheel bearings??
by chief » Sat Dec 02, 2006 4:36 pm
i've been getting a wirring noise just lately, and i had a mate over to help me change the camshaft sensor, he said straight away it sounded like the bearing. had the wheels off and theres loads of play in both front wheels.
is this a hard job to diy and do i need any special tools?. also is there anything else i may as well do while im at it.
chief
by marko » Sat Dec 02, 2006 5:37 pm
not really a diy job, bearings are an inteference fit and pressed into the hub carrier. could save yourself some money by removing the strut and just getting the garage to press out the old bearing, did one myself on a gsi cav, took ages to get out.
marko
by Stupink » Sat Dec 02, 2006 7:48 pm
Check the hub nuts are tight. the specified torque is F-tight!
by chief » Sat Dec 02, 2006 10:19 pm
i'll check that stu, just trying to think when it started cos i changed the suspention a while ago.
chief
by Stupink » Sat Dec 02, 2006 11:54 pm
Probably all it is then, to do it up to the right torque (think its angle actually) you need a breaker bar pretty much. if you did it with a normal ratchet then it wont be tight enough.
by Stupink » Sun Dec 03, 2006 12:01 am
Strength of the ratchet not the issue [img]/biggrin.gif[/img] strength of the user is the problem [img]/biggrin.gif[/img]
by chief » Sun Dec 03, 2006 1:34 am
im pretty strong:rolleyes: i can hold two beers in each hand!!!!:beer: :beer:
:stfu:
chief
Users browsing this forum: Bing [Bot] and 7 guests
