help please rounded off head DOUGHNUT BUSH
by callicool » Mon Jan 08, 2007 11:35 pm
how do i get round this bloody problem? ive finally got round to doing my dough nut bushes and rounded the head of the main bolt!
after wedging on a smaller size socket one 1 side i managed to get it off and replace the bush.
only after putting the new one in and tightening it up it sat around 10mil out so i tried to take it off and it rounded off again now im stuck again.
the other side is worse it wont budge after heating it the old wd40 didnt work either what do i do money is low so i want to do it myself some one please <!--sizeo:6--><span style="font-size:24pt;line-height:100%"><!--/sizeo-->HELP!!!!<!--sizec--></span><!--/sizec-->
callicool
by Stupink » Mon Jan 08, 2007 11:47 pm
Did you clean the bolt up before refitting it? It's probably one of those you're supposed to use new bolts for, but the old one will have had threadlock etc all over it..
Is it dangling down far enough to get some stilsons on?
to be honest you woudlnt get a size smaller socket on it I don't think, so you probably started off with the wrong size. make sure its the correct one and use a 6 sided socket not a 12sided one.
by MJ » Mon Jan 08, 2007 11:57 pm
and a big bar
MJ
by callicool » Tue Jan 09, 2007 12:03 am
I used a single hex 18mil socket fitted nice, got the breaker bar on it and nothing in fact it was bending the bar then after trying again it went a mate says weld another bolt on it then do it again. what ever i do im going to need to buy new ones wheres best autovaux??? cheers
callicool
by vauaidy » Tue Jan 09, 2007 9:17 pm
whats the donut bush guys having a blonde moment
vauaidy
by MJ » Tue Jan 09, 2007 9:31 pm
its the rear beam mounting bush [img]/smile.gif[/img]
MJ
