New shocks and springs
by SukySaggi » Sat May 29, 2004 1:57 pm
Hello all,
I have just had my tracking checked and found that the front drivers side is all over the place. I was going to get it aligned but the mechanic said that my front springs and/or shocks could need replacing. [img]/sad.gif[/img]
How can I check for sure without actually removing the shocks and springs. and if they do need changing which set up would you recomend. I wouln't want to drop the car too much cus it's on stndard 16 alloys. [img]/sad.gif[/img]
Brgds Suky Saggi (bog standard C20LET with dodgy bumper)
Also why it called Nautilus Blue when it@s clearly dark Green :?
SukySaggi
by MarkV6 » Sat May 29, 2004 8:31 pm
There is a bounce test for the 'dampers' (technically the springs absorb the road shocks but that's a different story)
OK, place both hands on one corner of the car and try to press it down to compress the suspension, quickly release, the car should bounce back up and settle down to where it was. If it bounces twice the dampers are worn.
1. down
2. up
3. settle
If the dampers are leaking oil then they should be replaced in axle pairs ie both fronts and/or both rears.
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by SukySaggi » Tue Jun 01, 2004 12:18 pm
Thanks for that. After the push test it appears that all my shocks are fine,
but my spring are very squeaky. Should I change them or just get my steering re aligned?
Brgds Suky Saggi (Bog standard C20LET with dodgy bumper)
SukySaggi
