Knocking from front
Knocking from front
I've had a knoking on the front of my cally more or less since I got it and it was eating ARB links so I changed both wishbones (and the rear bushes were both hanging out, that would explain the snapped ARB links!!) but theres still a knock, now its more like a crack, not all the time, mainly braking fairly hard at slow speeds (about 5-10mph) but noticed it more now we have snow, when it starts to spin the wheels a bit then suddenly gets grip theres a nasty knock
All the bolts in the wishbones are tight, the bottom ball joints are brand new with the wishbones and the nuts are tight, 2 new ARB links so again, nice and tight
What could it be? Strut tops maybe? The steering is still smooth with no nasty noises, got me puzzled!
Answers on a postcard!
Thanks,
Rob
Thanks,
Rob
ValverRob
Right, I've checked springs, brake calipers and wishbone bolts, all good, but it's still knocking, I can make it happen by reversing slowly then braking hard, then moving forward slowly and braking hard, my girlfriend said she can feel the knock through her feet, is there anything suspension related that's under/near the passenger side footwell that could be worn?
What about arb bushes, where it mounts to the car, how easy are they to get at to check/replace?
Thanks,
Rob
Thanks,
Rob
ValverRob
<!--QuoteBegin-wantredtop+--><div class='quotetop'>(wantredtop)</div><div class='quotemain'><!--QuoteEBegin-->if your arb link breaks and needs replacing, it is easyier or more viable just to replace the whole wishbone? becuase wont that include the arb link?<!--QuoteEnd--></div><!--QuoteEEnd-->
No, ARB is seperate
No, ARB is seperate
Knocking front end
[font=Arial] [/font][B]My poor 1992 Calibra is still knocking! I replaced ARB pendulem link, after discovering it smashed to pieces (fancy making it out of plastic!!) There are no obvious visable problems, just a knocking noise... Sounds like it is coming from the front drivers side wheel arch area. Any ideas??
Pirate
