ABS light
ABS light
Hey guys,
My ABS lights comes on every so often, either when I have to break pretty hard or when I hit a bumpy road...havent done the paperclip test but will have a look sunday...any ideas what it could be? Once when I had to break hard the brake pedal felt like it was juddering?
Thanks
Kelly
Thanks
Kelly
kellystewart
yeh sounds exactly like the prob i had for a while.. my sisters mk3 astra is doing the same thing too, only without the abs light.. its been in and out the garage for months and the problem still aint been found!
if you find the prob and need any parts i have a 16v cally for spares, i assume the abs is the same as the 8v
heavenly_d3vi1
If your ABS isn't working correctly then your wheels could be locking up whilst your still in gear causing it to stall the engine so that could be why your engine is dying.
The ABS light comes on and stays on when there is a fault in the system. When its on, the system is not in use and reverts to manual control.
I believe the light does flicker when its being used though....like the traction control light does (if you have it fitted).
Are you braking REALLY hard when this happens? Does the car pull either way left or right when your braking?
not particularly hard...only had to break really hard once and thats when I felt the judder through the pedal. The other 2/3 times it cut out was when I went over a bumpy part of the road. It pulls slightly to the left when I brake its always done this but I have noticed its worse now than 3 months ago
kellystewart
You may possibly have 2 seperate faults there.
As for the brakes, if the car is pulling to the left, there is a chance your brake biase may be faulty putting more pressure to one side or wheel. This in turn would cause it to pull to one side and allow a wheel to lock up more easily.
Does the car pull to the left when your not braking?
If its not the brake biase (they don't go wrong very often) and its not your brakes causing the car to pull then it could just be a faulty sensor as these are known to fail. Also, check the ABS rings...sometimes these break up or they could just be dirty giving a false reading.
Users browsing this forum: Bing [Bot] and 16 guests
