v6 rear brakes
v6 rear brakes
marko
Had the same problem with mine, they are only 270 if you get the 286 the part that the handbrake shoes fit in to is to small.
Blackdiamond PT No KBC599G12 well thats what is on the box.
marko
Just some off the shelf from Halfords.
No, the bit that handbrake goes in is not the right depth(to small).
<!--QuoteBegin-ash_pearce+--><div class='quotetop'>(ash_pearce)</div><div class='quotemain'><!--QuoteEBegin-->ive got exactly the same problem, started as just replacing the handbrake shoes, now needs new discs and pads. bought some today not knowing the size issue!! why cant things ever be simple! so the correct size for the v6 should be 286? is that right?<!--QuoteEnd--></div><!--QuoteEEnd-->
No you need 270mm, all mags show 286 but most seem to need 270 but check just run a tape over them.
Well they come up well.
