H frame
H frame
by stainesy » Mon Apr 23, 2007 9:10 pm
i gota put my calibra into the garage tomorow to get a new H frame.
there is a loud bang everytime i brake or steer. i thought is was a ball joint turns out my H frame where the wishbone is atached is propper busted. i had to go salvage yard and managed to get a new one with both wishbones atached for £35. its gona cost £130 to get new one fitted.
what a relife i thought it was gona e a mojor job.
stainesy
by Rusty_CallyT » Mon Apr 23, 2007 10:16 pm
probably clouted a kerb at some point and weakened it, now with time its given up
Rusty_CallyT
by stainesy » Mon Apr 23, 2007 11:07 pm
when i took it in to be checked they said that the main bolt that holds the wishbone on was loose and over time it had rattled about and slowly made the hole bigger and bigger and now the bolt hole on the H frame is not repairable. thatnk god thats all it it was.
stainesy
by MJ » Mon Apr 23, 2007 11:16 pm
£5 says it was northview that told you that
MJ
by stainesy » Mon Apr 23, 2007 11:30 pm
nope it was car pro
stainesy
by MJ » Tue Apr 24, 2007 12:07 am
bugger, i'll look out for you next time im in town lol ..... but i'd get a second opinion .... everything metal is fixable to someone with decent welding gear
MJ
by stainesy » Tue Apr 24, 2007 7:41 am
you in dunstable then?
stainesy
by MJ » Tue Apr 24, 2007 1:23 pm
used to be about 2 mile away, moved up to scotland 4 years ago though
still down quite often for family etc
MJ
by MJ » Fri Apr 27, 2007 12:04 pm
remember me/the car?
MJ
by stainesy » Fri Apr 27, 2007 2:26 pm
ok ill memorize the car. so next time i see u i will say hi.
stainesy
by Naz » Fri Apr 27, 2007 4:46 pm
<!--QuoteBegin-stainesy+--><div class='quotetop'>(stainesy)</div><div class='quotemain'><!--QuoteEBegin-->its gona cost £130 to get new one fitted.<!--QuoteEnd--></div><!--QuoteEEnd-->
Jesus, that much to change a H frame?!
It only takes about an hour at most to change a subframe! I make it £130 per hour garage! Thats one expensive garage!
Naz
by Phantom » Fri Apr 27, 2007 4:52 pm
lol I'll do it for £75 [img]/wink.gif[/img]
Phantom
by stainesy » Fri Apr 27, 2007 5:47 pm
i would do it myself but i aint got the tools. oh well its booked in for monday now. at least its done and out the way then
stainesy
Users browsing this forum: Google [Bot] and 10 guests
