Vibrations
by Mac » Fri Jun 11, 2004 8:47 pm
Hello , got vibs coming through steering wheel ,entire dash shakes, car feels like you are going over cobbles permenatley. Any speed over 30mph, gets worse the faster you go!
Tried- Balance all 4 wheels
Ballanced again (front 2) on the car
Checked tyre inflation
Can't find any mega worn bushes
I am now lost as to the solution,so are the boys at the garage,
Can you help?
Also have post about spluttering can you help?
Mac
by MarkV6 » Fri Jun 11, 2004 10:10 pm
Are you running on non-standard wheels ie 17" or 18" if so, check the spigot rings are there and ok. These centralise the wheels to the hub but if you don't have them you get your symptoms
Are the tyres going out of round or are your wheels buckled??
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by Mac » Sat Jun 12, 2004 4:30 pm
Cheers MarkV6, The rims are 16" 5 spoke (think they are an old tsw make) had 2 new front tyres, Dunlop 205/55/16 (£105 a side) the plastic spigots are there, cleaned the mating faces with a wire brush, The problem aint as bad but its still there.
Mac
by Robert_Dale » Sat Jun 12, 2004 6:07 pm
Dude if they are after market alloys the sprigot rings will be different to the standard plastic ones, take a wheel off and if you can move it about on your hub with the ring on then thats the probem mate
Rob
Robert_Dale
euro 2004
by Mac » Sat Jun 12, 2004 8:14 pm
Cheers Rob ,I will try to give it a wiggle.
Mac
by Phil69 » Mon Jun 14, 2004 2:06 pm
Yep, heard this one before,
As already said, its likely to be the spigot rings. Any ring of the correct size should be ok but personally, I'd rather have a brand new set of metal ones on there. Much stronger and if you buy new ones then you know they are gonna fit. Speak to a alloy wheel supplier. They should be able to sell/give you a set and they don't very much.
by Phil69 » Mon Jun 14, 2004 2:07 pm
Sorry - meant to say they don't COST very much
HOW THE WORLD WAS MADE!
by Mac » Fri Jul 02, 2004 2:03 pm
Cheers fella's ,Been away for awhile their, will try new metal spigots. [img]/tongue.gif[/img]
Mac
Users browsing this forum: No registered users and 103 guests
