Convergence on Real Wheel, Camber on Front Wheel
by DeepSnoozer » Sat Jul 07, 2007 1:35 pm
I'm gutted, i found out that within a year of carefull driving i've developed a slight non worring camber on the front wheel of a 10th of a degree or so, but the most worring part is in the back with my driver's side rear wheel is opened 2 milimiters , i've looked carefully underneath and i only found the pad where i usualy put the jack to rise the car was a little bit bent (just a little bit).
The bit question is: i also know that my bearings are going, the fact that i'm on the road and i dont hear a sound but when i go over bumpy roads all hell breaks loose (lots of clinging sounds) makes me belive that the 2mm convergence is being caused by that.
What do u think mateys?
DeepSnoozer
by DeepSnoozer » Sat Jul 07, 2007 3:07 pm
Please would any mod. move this to the correct place? suspension and steering part?
DeepSnoozer
by DeepSnoozer » Mon Jul 09, 2007 1:36 am
i found that my bearings are okay after all, i'm suspecting this might be the problem
it's scratched and a little bit bent (on the edge) i probably hit it in a forward direction somewhere..., what do u think?
DeepSnoozer
