Slight knocking sound
by Calibra_Mike » Thu Jul 26, 2007 7:12 pm
Seems to only happen when im turning at low speed, Ive got under the car and checked the CV joints, they look fine, the ball joints look good, couple of the bushes look like they've had better days, would that be the cause? The car is sitting on lowering springs aswell, anyone had this same thing when they're lowered their cally, just wanna make sure its a real problem before i go getting new parts...
by baby9bird » Thu Jul 26, 2007 8:11 pm
Mine does that been told its the springs moving!
baby9bird
by Calibra_Mike » Thu Jul 26, 2007 9:41 pm
Yeah that could be it, it has that sound and i guess where its been lowered its under a little more stress that the stock springs would be...
Is there a way to stop them moving I wonder? :s
by biffbangpow » Fri Jul 27, 2007 10:25 am
i always thought it could do with a strut brace, plenty about, someone on here might have 1 ,or ebay
biffbangpow
by Calibra_Mike » Fri Jul 27, 2007 2:42 pm
Yeah thats on the list of future parts, a strutbrace would certainly give it a bit more stiffness on the corners...
by Phantom » Wed Aug 01, 2007 12:08 am
if it was a CV joint the knocking would be continuous when on full lock, if its just a single knock each time you turn then it could well be the springs moving, have you checked your antiroll bar drop links and the suspension top mounts?
Phantom
by Calibra_Mike » Mon Aug 13, 2007 8:02 am
drop links look ok, not checked the top mounts, although I found out the other day when i was painting my calipers that the f/o/s shock looks like its leaking, I take it stock shocks aren't gas? also I notice that with the wheel off and me rotating the driveshalf I get a slight noise from that once every full turn, could the driveshaft be on its way out?
by Calibra_Mike » Thu Aug 23, 2007 10:53 pm
^^^^^^^^^^^^^^^Advice people^^^^^^^^^^^^^^^^
by Robs-se » Sun Aug 26, 2007 10:48 am
If you have had the shocks changed then check the big nut that secures the cartridge to sleeve thing.
Mine hadn't been done up tightly enough so there was a bit of play in them.
Also if you open your bonnet and turn the steering wheel you ban see the top mounts moving about,
maybe these need to be renewed. i know mine do as i can see then moving.
Rob
by Calibra_Mike » Sun Aug 26, 2007 12:09 pm
Thanks will check that too...
