creaking wheel?
by Fraggies Dad » Sun Sep 09, 2007 1:29 pm
help guys,
just got back from shops in the V6, when going very slowly getting loud creaking from o/s front wheel. this gets quieter as you speed up, seems to me like wheel bearing..... how big a job is this? do i need special kits etc?
thanks
Fraggies Dad
by Calibra_Mike » Tue Sep 18, 2007 8:06 am
Not sure if its a wheel bearing if its a creaking noise, sounds more like a suspension component has failed or the wheel bolts need torquing up...
Best way to check a wheel bearing is jack the car up and see if theres any play in the wheel by rocking it, also spin it and listen for any unusal noises... The hardest part of a wheel bearing change is the pressing in and out of the bearing, get yourself a haynes manual, all we be explained...
by Fraggies Dad » Tue Sep 18, 2007 12:27 pm
Calibra_Mike wrote:Not sure if its a wheel bearing if its a creaking noise, sounds more like a suspension component has failed or the wheel bolts need torquing up...
thanks Mike, got the new bearing pressed in at work, all is OK again now
Fraggies Dad
