5 stud turbo rear hubs.
by ben lee » Sun Sep 16, 2007 9:21 pm
would it be possable to fit 5 stud turbo rear hubs to a non 4x4 calibra?
would leaveing the cv joint bolted up work?
wheres the abs ring on the turbos? have they got the same amount of teeth?
ben lee
by Stupink » Sun Sep 16, 2007 9:53 pm
abs ring is on the halfshafts inboard end. so you need V6 rear hubs, front turbo ones are ok tho.
by ben lee » Sun Sep 16, 2007 10:03 pm
was just a thought as its easy to get turbo parts but not the v6 ones.
ben lee
by Sean C » Mon Sep 17, 2007 5:49 pm
Just done this on my 8v cally i used the hole rear arm the abs rings can be removed from the 4 stud hubs and fitted to the rear of the 5 stud ones you will need a three legged puller to remove but it can be done
by ben lee » Mon Sep 17, 2007 6:57 pm
sean did you use turbo ones?
i know its poss to use v6 ones but can get hold of any just turbo ones at the mo.
ben lee
by Sean C » Mon Sep 17, 2007 7:05 pm
ben lee wrote:sean did you use turbo ones?
Yes i did i swaped the hole suspension from my scrap turbo
Users browsing this forum: Bing [Bot] and 2 guests
