What size bolt is on the end of the driveshaft?
by ross85 » Thu Nov 29, 2007 11:02 pm
As above - I'm having to replace the suspension strut on the redtop and haven't got a socket big enough to get the bolt out at the hub :( Looks like it could be a 26mm...
ross85
by cornishtaz » Thu Nov 29, 2007 11:07 pm
From what I can remember it's a 30mm and you'll need a deep socket, I had to buy one specially
Hopefully someone will confirm this as well
cornishtaz
by MJ » Thu Nov 29, 2007 11:24 pm
im pretty sure its a 32mm
MJ
by ross85 » Thu Nov 29, 2007 11:53 pm
A bit bigger than 26 then lol - but it's dark ;)
Will trip down halfrauds at lunch tomorrow then and see if they've got any.
ross85
by Rusty_CallyT » Fri Nov 30, 2007 12:17 am
i bought a set of huge deep sockets specifically for it, 32mm im pretty sure, makes taking the castellated nut off a breeze with an impact wrench
Rusty_CallyT
by MJ » Fri Nov 30, 2007 1:20 am
yep, i'd recommend a impact wrench if possible ..... its also a nut not a bolt but im sure you knew that!
MJ
by Calibra_Mike » Fri Nov 30, 2007 7:33 am
Mine needed a 30mm, halfords do them, think it was about a fiver...
by Fraz » Fri Nov 30, 2007 1:53 pm
its 30mm
by ross85 » Sat Dec 01, 2007 10:48 pm
Yep I meant nut lol.
Mine was a 30mm, got if from halfords for about a fiver. Borrowed a mate with an air gun to get if off and just got the new strut in tonight :mrgreen:
ross85
by cornishtaz » Sat Dec 01, 2007 10:51 pm
good to hear you got it sorted
cornishtaz
by cornishtaz » Sat Dec 01, 2007 11:36 pm
The last one I did I used crack bar and someone on the foot brake
cornishtaz
by Stupink » Sat Dec 01, 2007 11:41 pm
I'm supprised an airgun removed it tbh if its just a normal handgun type, it should be done up tighter than that, have used heavy duty airguns before to remove, but normally ahve to use the breaker bar and another bar+wheel bolt etc to remove and tighten. bearing soon dies if its not tight enough.
by ross85 » Sat Dec 01, 2007 11:46 pm
Lol well he said it came off straight away, I was at work this morning when he came round and did it.
ross85
