Handbrake not staying up
by pas » Fri Mar 07, 2008 9:05 am
Well it does sometimes but mostly it falls down if I shut the door little harder, or while I'm still in the car - as teeth are worn - I can hear them when Im pulling it up and it seems to hold better if I pull it towards passenger side (LHD) then drivers or straight up. When it goes down you can hear teeth - but it goes down really quick not teeth by teeth.
I am going to take off center column tomorow and try to fix it - thinking it may be metal around teeth got expanded (loose) during time and it just needs pushing it back together... hope I wont have to change whole handbrake handle mechanism...
If anyone had similar problem and has any suggestions I would be grateful for any advice before I start taking it apart.
pas
by Callyman » Fri Mar 07, 2008 9:08 am
Might not be the main teeth at all, there is a small piece that locates into these teeth held by a spring, could be that at fault?
by Mark1 » Fri Mar 07, 2008 10:41 am
To much pulling on the handbrake without pressing the button in.
by luke_16v » Fri Mar 07, 2008 11:44 am
Mark1 wrote:To much pulling on the handbrake without pressing the button in.
i agree, probly warn the ratchet out lol
luke_16v
by Phantom » Fri Mar 07, 2008 2:59 pm
hmm I never pull my button in and mine's ok and done 212k miles now
Phantom
by MarkV6 » Fri Mar 07, 2008 9:39 pm
Phantom wrote:hmm I never pull my button in and mine's ok and done 212k miles now
Yes but 200k of those could've been up and down a motorway.
The rachet part of the handbrake lever is what will hold it. Worn lever is most probable cause.
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by C411BRAnut » Sat Mar 08, 2008 12:26 am
Never had this problem - I listened to my driving instructor! :D
C411BRAnut
by Mark1 » Sat Mar 08, 2008 8:29 am
And the Corsa "D" handbook tells you not to press the button in :?
by luke_16v » Sat Mar 08, 2008 11:20 am
lol, but corsa d is pants anyway, looks liek a new micra on steroids, the ONLY 1 i'd consider is vxr
luke_16v
by Mark1 » Sat Mar 08, 2008 2:26 pm
I'm about to get my 3rd, only do about 15k and get a new one :cry:
