V6 Brakes
Q - Are turbo grooved discs standard on a V6?
A - Grooved discs aren't standard on any Calibra. They are, however, vented.
Q - Are Turbo and V6 brakes the same size? (Discs, calipers and pads)
A - Yes they are. V6 and Turbo's shared the same brake setup. However pre 1995 (up to S chassis) Calibra Turbo's and V6's are different to those brakes fitted to post 1995 (T chassis onwards).
Q - Would Red Stuff Pads last longer than Green Stuff ?
A - Red stuff are more for track and they operate at a different temp. As far as I can remember they are unsuitable for general road use. here's EBC's own spiel
Latest and greatest formulation for fast street use
Redstuff Ceramic pad compound will blow your mind when used in anger on faster street cars such as Evo, Impreza, M3, Skyline and anything quick.
An ECE R90 approved pad, legal for street use yet capable of stopping you from regular 100mph plus runs without fade. The pads just keep getting better the more abuse you give them.
Available for all faster cars both modern and classic.
Fast/Heavy Street Use
Brake well from cold
Effective to above 650°C
Low dust formula
Triple award winning EBC Greenstuff pads are now available in an upgraded AF44/78 formulation for most European cars, again ECE R-90 compliant, yet the new formulation offers higher thermal conductivity and therefore reduces incidents of brake judder, better cold braking and better wear life over previous EBC green formulations. EBC Greenstuff is an excellent fast A road pad for all road legal cars, but is not for track day use.
Low dust formula
jaybv6
Zero, the Stock V6 Discs and pads are good. I did mine on my last Calibra V6 and the braking effeciancy was off the scale when it went to the MOT station. Only if you are thinking about going on the track should you really consider a better brake setup.
As for cost, I replaced my front discs/pads and calipers all for £150 with the Vauxhall Trade Club.
jaybv6
v6 gearbox
Cool!
Gonna sort it then as the guy who owned the car before me installed turbo grooved discs and it costs so much more to maintain them.
ZeroRisk
Users browsing this forum: Google [Bot] and 14 guests
