Tyre pressures
Tyre pressures
by cornishtaz » Thu Apr 10, 2008 11:15 pm
I was checking my tyre pressures today and 3 of them were at 40psi and the other was low at 25psi.
As I've got aftermarket wheels fitted I can't seem to find anywhere what the correct pressure should be. My wheels and tyres are 215/45/17's, I'm thinking of adjusting them so the fronts are 34psi and rears 30psi.
Ca anyone let me know if this is correct or not
cornishtaz
by RobbieV » Thu Apr 10, 2008 11:25 pm
Recommended tyre pressure is 34 psi front / 31.5 psi rear.
(info from V6calibra.com)
by cornishtaz » Thu Apr 10, 2008 11:29 pm
That figure is for the original factory fit so it would be the same even though I've got wider but lower profile tyres?
cornishtaz
by RobbieV » Thu Apr 10, 2008 11:31 pm
cornishtaz wrote:That figure is for the original factory fit so it would be the same even though I've got wider but lower profile tyres?
It what i use and most tyre fitters say same pressure as original tyres hence why you can't find any info on tyre pressures for aftermarket wheels.
by cornishtaz » Thu Apr 10, 2008 11:33 pm
Nice one Rob thanks for info
cornishtaz
by callyben » Mon Apr 14, 2008 10:38 pm
i always drop a couple of psi on thinner sidewalls, you can always contact the tyre manufacturer
callyben
by big_gordy » Mon Apr 14, 2008 10:45 pm
hmmm ive always had mine @ 30psi all round
Tigra Chequers 1.6 - # 2 Car
by bodgetastic » Mon Apr 14, 2008 11:27 pm
big_gordy wrote:hmmm ive always had mine @ 30psi all round
Theirs a lot more weight at the front 8)
by RobbieV » Mon Apr 14, 2008 11:28 pm
So that's why he's called Big_Gordy ..................... :lol:
by trev150 » Mon Apr 14, 2008 11:46 pm
A smaller tyre size has no bearing on the required pressure as all that changes is the volume of air required to inflate it to said pressure.
I have always ran at manufacturers suggestions.
by big_gordy » Mon Apr 14, 2008 11:52 pm
now i didnt see that 1 comming.btw i am now on a DIET lost 10lb in 1 week
wohoo
