Suspension/steering issues
the cally went through its mot fine no problems or advisorys, however in the last couple of days im getting a knocking/cluncking from the front end, arb links are fine as are the bushes, wishbones all ok, suspension seems fine on inspection no springs broken or cracked top mounts appear ok and i cant see any issues with the engine mounts either im at a loss any suggestion all or advise on what to look at for...
RAINMAKER
vinny_69
Lol you aswell i had not long put up a post with the exact same problem, i know my strut top mounts are shot, place your hand on top of the turret under the bonnet and bounce you can feel the knocking.
Also i replaced the driver side mount it had not gone but was very weak, again yours may look ok but have you taken it off to check?
Now the main reason for my knocking on acceleration/changing down going over bumpy surfaces is the inner c.v's both sides are worn, again easily checkable although you probably know already, cup your'e hand around the inner c.v whilst at the same time holding the shaft and twist the inner c.v also try pulling it up and down, if there is any play this will be your problem as the c.v is a precision made part and there should be no play.
DiDi16v
rainmaker10 you were right about the top mounts all knocks and bangs have gone but there is a vibration through the car feels like rear end causing it and still a tiny bit of steering wheel wobble, i do have 1 odd size tyre on the rear 3 tyres are 205/40/17 and the other one is 215/40/17 would this be the cause?
DiDi16v
