Omega MV6 - 3.0 Front Calipers to Calibra V6
Hello All,
I have got Opel Calibra V6 and I bought front calipers from Omega 3.0 MV6 and as everybody know it has got 296x28 front brake disc, but it is not fit to Calibra. Where can I bought 296x28 brake disc which is fit to Calibra V6?
Thank you.
Regards,
Lui
Thank you.
Regards,
Lui
Laliiii
Re: Omega MV6 - 3.0 Front Calipers to Calibra V6
What size wheels do you have?
As far as I know no body does, you can get a kit with 308mm discs but you will need 17" wheels.
brake disc size as standard is either 284mm early or later models have 288mm, the Vectra GSI has the right size caliper brackets for the 308mm disces which you can get off e-bay for £100
Phantom
i spoted it
i tryed to fit them but there was going to be so much work in a machine shop it wasnt worth the hassel and ended up with a set of 308mm dics and calipers, i got them from a freind but im sure they came from LMF
Thank you to Everybody. I contact with LMF concerning to the disc.
Laliiii
