drive shaft/cv boot
drive shaft/cv boot
by vinny_69 » Thu May 14, 2009 4:22 pm
last time me and Tazz removed the d/s drive shaft the boot was weeping nothing special really :roll: now its gushing :( easy enough to replace,but would it be worth it in the long run to replace the drive shaft too?
can you get a spanking new shaft with cv and boot all in ?
one more question can you replace the abs jobbys without replacing the joint?
vinny_69
Re: drive shaft/cv boot
by vinny_69 » Thu May 14, 2009 5:31 pm
so i take it they dont go very often then?
had a little looky around and its either 6 squid for a boot or 60 squid each side (shaft,cv and new abs rings)
vinny_69
by Robs-se » Thu May 14, 2009 7:34 pm
need to do something to my boot as well mate, the small neck has slipped down and thrown a load od grease on the inside of the wheel arch. Need to get some more grease and and new cable tie and this time put it on tighter.
by vinny_69 » Thu May 14, 2009 11:37 pm
the kitt i had a look at came with grease boot and the metal thingys :mrgreen: i think one shall give em a go the weekend
vinny_69
by Robs-se » Fri May 15, 2009 12:26 am
Good luck, can the grease be brought separatly or only in the kits?
by vinny_69 » Fri May 15, 2009 1:22 pm
will let you know later rob as i is going shopping :D
vinny_69
by Stupink » Fri May 15, 2009 4:13 pm
you can buy it seperately at most motorfactors, just ask for cv grease.
by vinny_69 » Fri May 15, 2009 4:15 pm
damn you beat me to it stu :banging:
vinny_69
by Robs-se » Fri May 15, 2009 10:55 pm
Thanks guys, something for me to do on my days off next week
by vinny_69 » Mon Jul 20, 2009 6:23 pm
i know its an old thread but ive only just got round to doing it :roll:
replaced my drivers side cv boot saturday :D easy peasy only problem i have now is my break pedal travels a long long way down till i start slowing,i have no idea why as i never took the caliper off so im just gonna bleed it tomorrow and see if that fixes anything :oops:
vinny_69
by Robs-se » Fri Aug 07, 2009 8:45 pm
Have now got a tube of grease, how easy will it be to get the grease in with the boot still in place. Thinking of using a pointy thing like from glue tubes and putting it under the end of the boot and squirting in a bit at a time. Anyone any other ideas?
by Robs-se » Fri Aug 07, 2009 10:52 pm
thanks
by vinny_69 » Mon Aug 10, 2009 1:35 pm
don't forget if you need a hand :wink:
vinny_69
by Robs-se » Mon Aug 10, 2009 3:29 pm
vinny_69 wrote:don't forget if you need a hand :wink:
You'll certainly hear me shouting, now your an expert, cheers
by vinny_69 » Mon Aug 10, 2009 4:13 pm
it's not rocket science Rob i even did the old mans inner and outer on his corsa C :D
vinny_69
