Jacking/axle stand points - Haynes picture doesn't match car
by schumiisking » Fri Aug 14, 2009 7:12 pm
Hi,
I've attached some pics of the underneath of my car at the front (normal size!).
I've read the Haynes section where it says where the points are but I can't see it from where I'm looking and it doesn't make it clear.
Can someone please tell me where the appropriate points are? Im trying to change my brake pads and want to support the front on axle stands but Im not sure where to place them. I need a location that I can jack up, then slide the axle stand in!
Appreciate the help by the way. I've had this 1993 redtop cally since 2006 and keeping it going till it completely conks out! With your help I can keep it going.
Thanks.
Picture 040 copy.jpg (42.72 KiB) Viewed 13923 times
Picture 041 copy.jpg (36.73 KiB) Viewed 13924 times
Picture 042 copy.jpg (68.86 KiB) Viewed 13924 times
schumiisking
Re: Jacking/axle stand points - Haynes picture doesn't match car
by Fraz » Fri Aug 14, 2009 7:23 pm
the jacking points are on the actual Cill...though I never use them myself
by schumiisking » Fri Aug 14, 2009 7:25 pm
isn't that for the vehicle jack tho? thats what haynes says. ive got a hydraulic jack and it stresses to use the hydraulic jack on the appropriate hydraulic jacking point - as it says its different to the vehicle jack.
schumiisking
by v6 steve » Fri Aug 14, 2009 7:58 pm
i alway jack up from the big bush at the crossmember
by Fraz » Fri Aug 14, 2009 8:02 pm
whats wrong with the location you have the stands now??
and that is the place I would use a jack ...or the larger bush on xmember
by schumiisking » Fri Aug 14, 2009 8:38 pm
yeh thats the problem, due to the wide base of the axle stand it takes up a lot of surface area.
yeh the car is on axle stands atm but i forgot that to change the brake pads (and take wheels off) to undo the nuts i have to loosen them when the car is on the ground first (doh!).
so now i need to jack it up again. remove axle stands. drop it down. loosen wheel nuts. and put it back on axle stands.
I just want to make sure im jacking it up at a safe appropriate place.
schumiisking
by schumiisking » Fri Aug 14, 2009 8:40 pm
Fraz wrote: ...or the larger bush on xmember
where is that Fraz? sorry im a n00b in terms of the actual technical names of these suspension parts.
any chance you could draw an arrow on the pic somehow?
schumiisking
by v6 steve » Fri Aug 14, 2009 8:41 pm
get somone to put there foot on the brakes and then you can undo the bolts without putting it back down
by v6 steve » Fri Aug 14, 2009 8:43 pm
in the last pic its just right of the stand big round thing
by schumiisking » Fri Aug 14, 2009 9:45 pm
ok so just jacked the car up with the hydrau. jack where Haynes says you're not supposed to - at the vehicle jack locations.
nothing dramatic happened.
i've now got another problem in my changing pads journey: im struggling to push the cylinder back in to fit the new pads - any tips/ideas?
or is it supposed to be proper hard.
schumiisking
by schumiisking » Fri Aug 14, 2009 10:07 pm
k thanks i was hoping there was some magic easy option for pro's.
guess i'll either do that or use a C clamp.
schumiisking
by vinny_69 » Fri Aug 14, 2009 10:22 pm
G clamp always works :D
vinny_69
by Fraz » Fri Aug 14, 2009 10:27 pm
leave old front pad in, hold calliper (or put bolts back on) insert large type lever between piston and disc, apply pressure to piston
oh an remove brake reservoir cap
thats what I do
by bodgetastic » Sat Aug 15, 2009 12:30 am
I usually jack up on the subframe and insert axel stands where you have located them or the other way round. Usually take out the pads and push the piston in with a bar but take off reservior cap first
More power than God
by Robs-se » Sat Aug 15, 2009 11:25 pm
Use a large flat bladed screw driver on the edge of the cylinder and take the resevoir cap off as well
