what rear brakes for calibra turbo???
by vaggelis00 » Tue Jan 05, 2010 9:54 am
what options do i have for bigger rear brakes than the 270mm i have already?
my front brakes are tarox 6 pot with 318mm discs and i need something better for rear
vaggelis00
Re: what rear brakes for calibra turbo???
by D-Man » Tue Jan 05, 2010 12:33 pm
You can go for Omega B rear brakes.
by vaggelis00 » Tue Jan 05, 2010 12:57 pm
they are hard to fit?
vaggelis00
by vaggelis00 » Thu Jan 07, 2010 7:19 am
any help?
vaggelis00
by D-Man » Thu Jan 07, 2010 11:58 am
I'll try to get this info for you ;)
by vaggelis00 » Thu Jan 07, 2010 1:23 pm
front brakes are adequate but i need to upgrade the rear brakes because they will look nicer ;)
D-man waiting for the info mate. thanks
vaggelis00
by D-Man » Thu Jan 07, 2010 3:31 pm
Complication of installation depends on type of brakes You presently have.
As I understood, if You have later type brakes, then it is almost plug-n-play.
If brakes are of earlier type then You'll have to apply some handjob :mrgreen: But not so hard as well.
by bodgetastic » Thu Jan 07, 2010 5:56 pm
why not have a word with Tarox and get some to match the fronts :mrgreen:
More power than God
Site Moderator
Site Moderator
by vaggelis00 » Fri Jan 08, 2010 12:38 am
Tarox were bought from ebay so payed just 449 pounds for them. i have the early type i suppose because my front brakes were the early type 284mm
vaggelis00
by U_V6 » Thu Jan 28, 2010 9:12 am
that's why D-Man asked about my rear setup...
280mm discs (rear) from Omega B with Omegas rear callippers (40mm) are on my Calibra.
on later type brakes (with 288mm in front) - it should be plug & play.
on earlier type brakes (with 284mm in front) - it needs some machining(so the 'thingie' on which wheel is sitting - goes deeper in bearing) and changing bearings. it might get clearer when you compare rear disc dimensions - for example in brembo catalogue (http://bremboaftermarket.com/) - especially - hub's height.
p.s. sorry for my english - sometimes it's :banging: :whistle:
U_V6
Users browsing this forum: No registered users and 82 guests
