Front wishbones
Front wishbones
by bodgetastic » Mon Mar 22, 2010 12:25 am
Tightened up the bolt going through the bottom ball joint today, went it nice and square after a bit of swearing at the dam polybushes but has threaded and just spins now :evil:
Whats the best fix :roll:
More power than God
Re: Front wishbones
by Calibra_Mike » Mon Mar 22, 2010 7:32 am
or are you talking about the anti-roll bar link with the ball type joint on it?
Re: Front wishbones
by Mark1 » Mon Mar 22, 2010 9:05 am
Run a tap down it may recut or you maybe able to put heli-coil in it.
Re: Front wishbones
by v6 steve » Mon Mar 22, 2010 12:07 pm
you'll need to cut a hole in the footwell and weld the bolt or new bolt back in place
Re: Front wishbones
by bodgetastic » Mon Mar 22, 2010 4:03 pm
I cant really visualise where it comes up or how far out the bolt pretudes, can I just simply drill through and just put a nut on the top of the bolt?
More power than God
Re: Front wishbones
by Fraz » Mon Mar 22, 2010 4:28 pm
its at a bit thats double skinned, so would need a rather long bolt ...and it would be sticking out right where your feet will be
Re: Front wishbones
by bodgetastic » Mon Mar 22, 2010 6:04 pm
Fraz wrote: ...and it would be sticking out right where your feet will be
Fine, its passenger side :lol: :lol:
Will have a looky under the carpet tonight. Is it visual or am I gonna be cutting holes all over the footwell tonight.
More power than God
Re: Front wishbones
by bodgetastic » Mon Mar 22, 2010 6:32 pm
Good plan.
So I could drill a hole in the top skin and put a nut on the bottom where the bolt comes through? Im sure it will make sense later? May try and tap a new thread first and get a bigger bolt?
More power than God
Re: Front wishbones
by v6 steve » Mon Mar 22, 2010 8:18 pm
i wouldn't think the floor pan will be stroing enough too take the presure that it will be put under, i would dril a hole from the subframe side up so you know where to cut the floor then ut off old bolt and replace it
Re: Front wishbones
by KERR_SE9 » Mon Mar 22, 2010 8:38 pm
Same thing happened to my Le, someone, cut a small hole in the floor skind and welded a new bolt in place, welded it back up again, then seal up floor (waxoyl etc) Either that or a heli-coil.
Re: Front wishbones
by bodgetastic » Mon Mar 22, 2010 9:22 pm
v6 steve wrote:i wouldn't think the floor pan will be stroing enough too take the presure that it will be put under, i would dril a hole from the subframe side up so you know where to cut the floor then cut off old bolt and replace it
Right still a little confused lol. What does the bolt screw into? Do you mean old nut rather than bolt lol. If I cut this off can I just replace with a nut rather than having to weld something in (bearing in mind I dont have a welder :lol: ).
Heli coil seems like the easiest option to me, any reason why it wouldnt take the torque, never used one before?
More power than God
Re: Front wishbones
by v6 steve » Mon Mar 22, 2010 9:32 pm
when you cut the floor there will be a bolt that should be weled on which is now broken off and spinning ether weld it on or use a new one and tighten to subframe bolt with a socket
Re: Front wishbones
by v6 steve » Mon Mar 22, 2010 9:44 pm
yee sorry i should have said nut not bolt me stupid
Re: Front wishbones
by Robs-se » Mon Mar 22, 2010 10:54 pm
I had this on mine and if i remember i posted on here what i did with pictures. i'll look out the thread.
Re: Front wishbones
by bodgetastic » Mon Mar 22, 2010 10:57 pm
Robs-se wrote:I had this on mine and if i remember i posted on here what i did with pictures. i'll look out the thread.
Nice one Rob. I did do a search as I think I remember something but couldnt find anything 8-)
More power than God
