how to tell apart pre or post '96 rear calipers?
by rich_DTM » Mon Apr 26, 2010 6:54 pm
does anyone know the physical difference of the early or late rear calipers?
i know pre '96 the discs were 170mm
and post '96 were 286mm
but how to tell the capilers apart as they have different part numbers for the pads!
rich_DTM
Re: how to tell apart pre or post '96 rear calipers?
by RobbieV » Mon Apr 26, 2010 7:08 pm
Rear discs were pre 260mm and post 270mm.
as for telling the difference - no idea.
by GreyDJ » Mon Apr 26, 2010 9:11 pm
That's strange, GM list the same pad for all Calibra rear applications.
All models disc pads 90485136
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
by bodgetastic » Mon Apr 26, 2010 9:48 pm
Autovaux sent me out some exchange calipers and the pads didnt fit because the pin spacing holding the pads was different. Would possibly have a different size piston too but really not sure. I think they have different numbers on them though which might help identify them or you could take the part number from the old pads?
More power than God
by big_gordy » Mon Apr 26, 2010 10:11 pm
"you could take the part number from the old pads"
good idea i would say!
Tigra Chequers 1.6 - # 2 Car
by GreyDJ » Mon Apr 26, 2010 10:41 pm
The 90485136 is definitely the right pads for my late Turbo but I have found big problems getting the correct fitting kit as the springs for the pins are not long enough.
by Fraz » Mon Apr 26, 2010 11:31 pm
thats casue they stopped doing the pins that go in from the front, you need to fit shorter springs and come in from the back of the backplate
by GreyDJ » Tue Apr 27, 2010 12:29 am
Fraz wrote:thats casue they stopped doing the pins that go in from the front, you need to fit shorter springs and come in from the back of the backplate
I am using the 'in from the back' pins, but the holes in the callipers for the pins are spaced too far apart for the pin 'hollows' in the springs.
