braded hoses
braded hoses
After alot of messing around finally got some braded hoses to fit well the garage i use did, the thing is i am a little dissapointed with the pedal feel, i thought it would be firmer or higher up what influences this or am i expecting to much. Dont get me wrong when you plant your foot it really pulls up, any thoughts wellcome.
Re: braded hoses
think your expecting way too much from simply fitting a set of hoses ...if you want better brakes fit bigger calipers and discs, Braided hoses just mean they last longer than the rubber ones ...and look better
Re: braded hoses
Hi Fraz, didnt mention because they,ve been on for a bit i've got the lmf bigger disc's on the front, they are the black diamond drilled and grooved all round with the predator pads, thought it might be a case of me expecting to much just was going off what other people have said. Like i said does stop well!
Re: braded hoses
it also depends on your tires and road conditions but my old V6 had mindex discs and pads plus braided front's and that stopped like it hit a wall given the ideal conditions, the braided lines do make the pedal more consistent when your feeling frisky maybe you need to replace your brake fluid
vinny_69
Re: braded hoses
What would you replace it with ( and yes for the smarty pants i know with more brake fluid) but what type to get better feel from the pedal or am i being unrealistic again.
Re: braded hoses
race speck is Dot 5 but i would just stick with some good fresh dot 4 flush all the crap out front and rear
vinny_69
Re: braded hoses
chris_p wrote:What would you replace it with ( and yes for the smarty pants i know with more brake fluid) but what type to get better feel from the pedal or am i being unrealistic again.
spoil sport
Brake Fluid
