Noise from Brakes
Noise from Brakes
OK so I fitted new discs and pads yesterday, after taking it for a test drive the passanger side was making a horrific noise, got back and found that the dust cover plate behind the disc must have got knocked or bent and was rubbing on the disc, so bent it back out the way and took the car out again, all good, no bad noises and the brakes work fine... HOWEVER... today I was driving back from a mates when i noticed a slight squeak coming from the passanger side again also they are starting to squeal a bit when braking lightly but that goes if you plant ur foot down a bit more... I had another look and the dust plate is not touching and with the car jacked up and I spin the wheel it doesnt make any noise...
so what makes brakes squeal? and what can i do to shut the bloody things up...
Re: Noise from Brakes
did you put copper slip on the back off the pads and along the slid bit?
Did you use copper ease on the back of the pads ?
v6 steve wrote:I beat MR V![]()
Woopi do
(Finger on delete button
yeah but I think I might put more on, just reading up online now about sqealing problems, says you might get some squeal noise because of the use of metal shavings in brake pads these days...
what are your discs like? it could be the bits of disc that havent seen a pad for some time being cleaned off
discs are new too...
^^^^^^^^^^^^does that look enough copper grease or should i stick more on?
yee that looks fine did you put any on the slid bit
nope... i'll stick a load more on tomorrow when im back from work... I just hate noisey brakes...
Make sure the sliding faces are clean too before you grease them up.
A good scratch with a screwdriver will do.
did you clean the discs with brake cleaner?? I know you proberbly have but you never know
I would take pads out, get your self some rough sand paper and give the pads surface a good going over ...take the shine off them and also do same the discs
the pads are EBC ones with a special brake in coating... yeah cleaned the discs up... Ill give everything a good going over tomorrow...
im sure your missing a clip in that pic! it should sit in the two holes and hook around the carrier lugs
- Club Member
