POWER STEERING FLUID
was woundering is there any bad or good power steering fluid ? ie like you get cheap nasty oil and then good oil?
if so what is a good brand for power steering fluid?
Tigra Chequers 1.6 - # 2 Car
Re: POWER STEERING FLUID
there all much the same, its not a race car so you dont need to worry about it to much just get what your local motor factor has on the shelf it will be fine
cheers for that steve !
Had to buy this like its going out of fasion from Halfords. They do a GM class fluid. Seems ok to me. On 4x4's though it an idea to use clear fluid if you can so that it makes it easier to see if its gone into the txb?
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
how would brake fluid get into the txd ?
