Brake problem
Brake problem
by Jesswest555 » Sun Mar 17, 2013 7:38 pm
I'm having problems with my breaks, keeps losing pressure. It's ok to start and then randomly it losses pressure and you have to pump them. They've been pressure bled and I can't find any leaks what so ever. No lose of fluid. PLEASE HELP!
Jesswest555
Re: Break problem
by STEVA » Sun Mar 17, 2013 7:57 pm
Seals gone in the master cylinder by the sounds of it
Steva
My Turbo
My Turbo Rebuild Thread
steva@clubcalibra.net
Re: Break problem
by Jesswest555 » Sun Mar 17, 2013 7:59 pm
Thanks very much, I'll take a look :)
Jesswest555
Re: Break problem
by rich30mex » Sun Mar 17, 2013 8:01 pm
STEVA wrote:Seals gone in the master cylinder by the sounds of it
Steva
You will have to tempt him back out with a fish or 2
:lol:
Re: Break problem
by v6 steve » Sun Mar 17, 2013 8:17 pm
if its not that i could be the servo, the se2 had the same problem till i changed it
Re: Brake problem
by Robs-se » Tue Mar 19, 2013 3:01 am
Same symptoms as when my master cylinder went
Re: Brake problem
by Jesswest555 » Wed Mar 20, 2013 7:38 pm
Cheers!
Jesswest555
Re: Brake problem
by Robs Calibra » Fri Mar 22, 2013 8:32 am
I need a calibra turbo 1996 Master Cylinder as I have same symptoms. I can't find one anywhere. Go on eBay and loads appear for calibras, but none for turbo?
Does anyone know where I can get one or would a saab 9-3 1998-2002 master cylinder fit? I was told it was the same?
Rob
Re: Brake problem
by Mark1 » Fri Mar 22, 2013 9:34 am
Rob have spoken to LMF or Autovaux as I would think one of them would be able to get the one you need.
Re: Brake problem
by Robs Calibra » Fri Mar 22, 2013 6:41 pm
Thanks, spoken to Autovaux, they ate checking suppliers on Monday. It's a mission to find one lol. Not sure what seals as to many on eBay and would not know how to do so just want to get a new one or one from a breaking calibra that is fully working.
Saab 9-3 turbo 1998-2002 supposed to be the same.?
Re: Brake problem
by v6 steve » Fri Mar 22, 2013 8:28 pm
arent the all the same apart from the v6 ? when i replaced the one on the se2 turbo i just took one out the shed dont know what i came off but it fixed the problem
Re: Brake problem
by Robs Calibra » Fri Mar 22, 2013 8:49 pm
No I don't think they are all the same. The turbo is different. Anyone confirm?
Re: Brake problem
by v6 steve » Sat Mar 23, 2013 10:51 pm
going by this there the same, cant see why they would be different
http://www.ebay.co.uk/itm/Vauxhall-Cali ... 19da5a494f
Re: Brake problem
by Robs Calibra » Thu Mar 28, 2013 2:38 am
So with 6 pot calipers on my le, is standard turbo master cylinder 23.88 bore ok, if not what's the upgrade?
Re: Brake problem
by Robs Calibra » Wed Apr 03, 2013 12:32 am
Anyone know if there is an upgrade master cylinder for 6 pot calipers?
