v6 drive shafts
v6 drive shafts
by HOT-ROD » Fri Jan 08, 2016 5:12 pm
My engine package has arrived today but I'm missing the short drive shafts and I also noticed the abs ring on the long shafts is damaged. :doh: I was wondering (I'm sure the answer is no) if the short shaft from my f18 will fit and if the outer part of the long shaft will fit? Don't mind tracking down a pair of shafts but would prefer not to if I don't need too!
Re: v6 drive shafts
by Allys Cally » Fri Jan 08, 2016 6:43 pm
with the damaged ABS ring you could just change over a cv joint off one of your own drive shafts if their in decent condition
