BIG brake upgrade dilema!!!!!!
Wheel nut covers wanted
OK, just got a set of 19s on my 16v ecotec calibra, so i was ready to spend over a grand on one of those lovely lookin hi-spec kits (the gold coloured callipers do it for me) until i found out that it was just for the front wheels!!!
So im lookin to upgrade to at least 320mm discs alround with nice looking calipers for both front and rear wheels. Does anyone know of or have fitted any kits like this?
Or should i get seperates (ie a set of 320mm discs from somewhere and a set of callipers from somewhere else)
PLEASE HELP!!
cheers guys & gals.
PLEASE HELP!!
cheers guys & gals.
ric
RE: 40mm drop. Before & after pics
first off i wouldnt bother with hi spec, never really rated them. go for tarox or something.
havent seen any rear conversions worth spending the money on, they dont really do a lot apart from look pretty anyway.
red dot also have some good prices on kits of you shop around.
gran
RE: BIG brake upgrade dilema!!!!!!
I have the 335's from <a href="http://www.godspeedbrakes.co.uk" target="_blank">www.godspeedbrakes.co.uk</a>
Very good brakes (The big reds (Brembo's) are Porsche calipers)
leegsi
Davidch
RE: Yet another newbie!
You don't really want to have the brakes on the back as good as the ones on the front, because it will make the car unsteady when you brake hard.
80% of all your braking is done by the front brakes, so don't buy any rears and just get some TEN POT CALIPERS from TAR.OX for the fron't they will be the best brakes you can get.
Just upgrade the rears to somthing a little better maybe 285mm with standard calipers?
Trev
Trev
cheers trev, just worried about it lookin a little odd with huge discs at the front and something resembling 5 pence peices at the back!
ric
LOL at ric's 19" alloy 5 pence piece!!
trev
trev
RE: U.S.Robotics 8054 Wireless Router...
Try swapping your flexible hoses for braided first. A fraction of the cost and probably more noticeable than a big brake conversion. The only reason to go for bigger brakes is for more heat dissipation and reduction in fade. If fade is your problem then go for the bigger discs as well. I know you can get different heat range pads but it's always a compromise...
MickM
IanW
