La la la another problem, brakes this time
Now my Black Diamond pads and discs are bedded, I thought I'd try seeing just how much better they are than the standards, so I tried braking down from about 60 MPH quite hard (though not OTT), and my battery light and ECU light came on (I'd dipped the clutch so it wasn't like the engine was stalling or anything). Went out as soon as I took my foot of the brake pedal
Tried it again, exactly the same thing.
I'm gonna read the ECU codes as soon as I can remember which pins to jumper on the connector (any ideas?), but in the mean time, any thoughts, as there also seems to be a bit or a rubbing noise when I do it (doesn't sound like the wheels catching the arches or anything).
projectx
Hmmm, you could be right K...Dunno though, as I also get a kinda whirring noise when I brake. Might just be the pads going over the grooves, and me not being used to really decent brakes, as my fronts have been warped for the past 6 months, and believe me, these brakes really do work now they've bedded in nicely.
Any ideas on what pins I need to short on the diag plug to get the ECU codes?
projectx
jaybv6
<!--QuoteBegin-thecrow+--><div class='quotetop'>(thecrow)</div><div class='quotemain'><!--QuoteEBegin-->Hi mate,
its pins A and B on the diag plug, they are labelled as you look down on it from above.
I think the whirring noise is just the grooves (my friend's Punto did the same thing with grooved discs)
Chris<!--QuoteEnd--></div><!--QuoteEEnd-->
Cool, I'll diag check it tomorrow and see if it has thrown anything up...Yeah I suspected the whirring was the grooves, that's certainly what it sounded like [img]/smile.gif[/img]
projectx
