digi dash?!?!?
The range function on the Trip computer is calculated by the Speeddo signal cable.
You have to make sure the Blue/red wire is connected to the blue/red wire of the trip comp.
The F on your Opel Vectra A 2000 Digi Dash is a failure signal.
Meaning there is something wrong with either the dash, or the wiring.
Did you connect the Check Control correctly?
1llusion
well yes the check control all goes out apart from the airbag light as that needs reset
all the functions on the F/C work (and range worked before fitting the dash) did hear that the chip needs reprogrammed though as its not the right one for the car ..its an senator one , as the original chip would not work in MPH and gallons
also heard that both the F/C and dash chip have to be the same programme number??? but not that sure
also do you know away to change the dash colour?
it is in german, but pics do say a lot.
The only way to get it realy blue.
http://www.rotanes.de/ninamama/
1llusion
Re: digi dash?!?!?
Could you send me that german site and all the information you have regarding wiring og fitting that dash?
I bought one of this dashes and I'm planning to fit it into my Kadett GSI. Thanks!
gsi2000i
Re: digi dash?!?!?
what gereman site???
Users browsing this forum: No registered users and 55 guests
