Set Belt Clip
Set Belt Clip
Hi Guys,
Usually I found that when I put on the seat belt it would clip into it's holder easily with a reassuring click.
Recently I found that I need to push down firmly to get it to engage, otherwise it will just come out, it no longers clicks.
From what I can see look at where the belt clips into the holder on both the front passenger and drive side belt holder thingy, there is white plastic bit on the inside of the driver side seat belt holder that doesn't seem to be coming back on release. That is, it seems to stay in instead of coming backing out.
Anyone got an idea how I can fix problem?
Re: Set Belt Clip
Get some other seat belt clips, Have you taken your seats out at all? If you have a later model you will have the seat belt tensioner, and if not correctly taken out they will go off and the clip is then useless.
If it is not this, my advice is still to get some replacements as safety is a must, IMO.
Re: Set Belt Clip
Thanks Mate,
I think your right this is probable the only option, I never taken the seat out before, but I am aware I will need to deactivate the tensioner before removal.
