would these seats fit in a calibra
would vectra GSi back seats fit in a calibra?
Tigra Chequers 1.6 - # 2 Car
Re: would these seats fit in a calibra
yes if your pockets are big enough ...no if you just want to swap them over and just bolt them in
whats involved then fraz?
big_gordy wrote:whats involved then fraz?
no idea you would have to compare them both................go compare, go compare
does anyone else know off hand?
Just buy them, try it, and if it dont work then sell them on?
no they wont fit would be cheaper to get yours retrimed, you could buy them take the covers off and try putting then on the callys seats but it will look s**t
cheers steve!
if bottom of vectra seats are flatish like the cali then a local fabricator should be able to make some sub frames out of yours to go onto the vectra bottoms??????
cally8valver
whats wrong with the Calibra back seat anyway ??
to be honest i find the calibra seats some of the comfiest around for short and long journeys and anything with vxr gsi seem a little hard after a whileFraz wrote:whats wrong with the Calibra back seat anyway ??
cally8valver
cally8valver wrote:if bottom of vectra seats are flatish like the cali then a local fabricator should be able to make some sub frames out of yours to go onto the vectra bottoms??????
the cally ones arent flat they are shaped and im sure te vectra ones will be bigger so the wont fit in the space
doh i should have known that as the seats raise manually besides like previously mentioned if you want them that bad and you got a few extra pennies ( pounds) aside to have some sub frames manufactured who to say it carnt be done like most modified interiors and exteriors if everyone stopped when someone said it casrnt be done all cars would be samev6 steve wrote:cally8valver wrote:if bottom of vectra seats are flatish like the cali then a local fabricator should be able to make some sub frames out of yours to go onto the vectra bottoms??????
cally8valver
cally8valver wrote:doh i should have known that as the seats raise manually besides like previously mentioned if you want them that bad and you got a few extra pennies ( pounds) aside to have some sub frames manufactured who to say it carnt be done like most modified interiors and exteriors if everyone stopped when someone said it casrnt be done all cars would be samev6 steve wrote:cally8valver wrote:if bottom of vectra seats are flatish like the cali then a local fabricator should be able to make some sub frames out of yours to go onto the vectra bottoms??????
yee your right what your saying but Big Gordy will just want to stick them straight in to his car
im sure the vectra base is a 3 seater,unlike the calibra which is a 2 seater so should be shorter?
i know the backs look smaller so doubt it would be easy,maybe if you handed your seats and the vectras to a trimmer it could be done,probably have to remould the foam backings to siut aswell.
specks
