sunroofliner removal??
just a quicky before a break clips or something...how it the sunroof liner removed?
thanks in advance.
thanks in advance.
k1nty
Re: sunroofliner removal??
just pull it out, it slots out and back in no probs and theres no clips to brake just needs a bit of pulling
wcKo
wcKo wrote:just pull it out, it slots out and back in no probs and theres no clips to brake just needs a bit of pulling
hmn mine had about 10 push type clips that all pulled off and ...exactly what i was trying to avoid,i can repair it so thanks anyway.
k1nty
Got any photo's of the clips as I counted mine and I've three push type clips attached to the liner and 8 other type clips attached to the outer skin. Will get a photo done shortly and someone can tell me if I'm missing any clips?
cheers
cheers
These are the push type clips, only 3 of them?
These are the spring type clips which are acting as a buffer for the sunroof liner
and this is the clip, which there are 8 of?
Anyone got any useful information, on how to Remove the Sunroof liner?
ask Gordy he has done that a few times
by sunroof liner do you mean the headliner??? if so as far as I remember it is this
you need to remove the sun visors, the grab handles, the interior light and then the seat belt upper mounts. the B pillar cover (where the seat belt goes)
I think after that you need to pull the back down at the taligate...not too far as there is a bar with little lugs that you need to carefully lift up ...from there I think you can then be able to pull the headliner fully out the way maybe need to get trim around the sides out the way a wee bit ...but I think you can get the headliner off without removing them
with the headliner off you can then access the sunroof ...few bolts and the drain tubes off and the electrics and the fully Assembly comes right off
cant you just take the sunroof liner off with out taking the whole roof down? not that i did it but when the drain got painted im sure the head liner was still in when the sunroof was put back in might be wroung i was asked to leave the garage when Fraz and Mr C did it, fresh paint lips and screw drivers no way was i staying to watch lol
Sunroof Liner Removal
After reading through this topic, it seems that there might be various types of roof liners!
Mine is the Two Stage - Twin Cog type Sunroof Model
Anyway, it turned out to be a really simple 2 minute job!!!
1 - Turn the Ignition ON, so that You can Operate the Sunroof...
2 - Using the Sunroof Switch, open the Sunroof past Stage One, and slide it back enough to expose the front of the liner...
3 - You can now pull down on the 3 Press Clips at the front there, and the front of the liner will drop...
4 - Once that's done, using the Sunroof Switch, gradually slide the Sunroof open and work the liner forward...
5 - Continue working the liner forward as you slide the Sunroof back, till the Sunroof is fully open...
6 - Then it's just a matter of working the liner, out towards the front of the car...
7 - Depress the 'Long Spring Loaded Retainer Bar' at the front in order to allow the liner to exit...
8 - Having an Assistant would make this Job even easier, but even a Novice like myself did it Solo...
Users browsing this forum: No registered users and 98 guests
