A Frame pannel
A Frame pannel
i have a leak coming from my driver side i think it might be the sunroof drain pipe blocked or split, how do i get the interior A Frame pannel off, does the dash have to come out, has anyone had a leak there????
If it's not broke, fix it until it is...........
Re: A Frame pannel
easy way to check is to open sunroof and pour some water down the drain see if it comes out the cill
the A frame trim can be taken out with out removing the dash ...been ages since I did it but recall it just pops off at the top then slide it up
Re: A Frame pannel
Could be the elephants trunk is blocked
Re: A Frame pannel
middle of the scuttle inside the engine bay ...usually get blocked and then the scuttle fills with water and leaks down through the heater air intake
but it usually the passenger side that get wet ...door seal, or the seal around the mirror are common for a leak ...as is a hole through the bulkhead or even a missing grommet or someone fitting something and needing a wire through and drills a hole and dont fit one
Re: A Frame pannel
Think I have found the prblem, its the door seal but cant tell where it starts have a feeling it could be up the top at the mirror point but how would I fix that?
Users browsing this forum: No registered users and 78 guests
