Alloy wheel size, offset, tyres...
Exterior & Interior Styling.
by Cliff » Tue Jun 07, 2016 9:27 pm
Hi
I am going to put some 17's on my Cliff (I still want some kind of ride comfort with where I live so anything bigger is out). Cliff is lowered out of the factory, same as the DTM I think (30mm?) - I absolutely don't want any rubbing or other hassles.
I currently have 205 55 16s (BBS) so I was thinking 205 40 17s - right size given the rim size increase? 205 or 215?
And for offset, I know GM have a high offset, highest I can get in the wheel design I am looking at is 42 - should be OK though I assume, low mileage per year anyhow - right?
Andrew
Re: Alloy wheel size, offset, tyres...
by Callyman » Tue Jun 07, 2016 10:25 pm
Think 215/40/17
Will give closer diameter/rolling circumference etc.
Good website to compare
Google 'willtheyfit'
by rich30mex » Wed Jun 08, 2016 8:22 am
Just curious Andy how did you come across that web site :shock: :lol:
by MarkV6 » Mon Jun 20, 2016 7:36 pm
Might be a bit late but this is a very informative website
http://www.carbibles.com/tyre_bible_pg4.html
has a nifty tyre size calculator about 2/3 way down the page too.
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by Cliff » Mon Jun 20, 2016 7:39 pm
Never too late, someone else will need the info at some point - thx!
by EddeyDancer » Thu Jun 23, 2016 9:19 am
Cliff wrote:I am going to put some 17's on my Cliff (I still want some kind of ride comfort with where I live so anything bigger is out).
And for offset, the wheel design I am looking at is 42 - should be OK
I've previously fitted, on ET40 wheels, I suggest tyre size of 205/45R17 with the option of fitting 225/45R17 on the Rear
Tyres of a 40 profile will give You a harsh ride, as well as looking too small for a Calibra on 17 inch wheels...
by JcSE6 » Tue Apr 29, 2025 10:23 pm
Know it's a long time ago, but did you change those wheels in the end?
Going through the same research now, was wondering what you're experience was if you had. Looking at a set of 7j x 17 ET40 Pro Race 1.2 with 205/45/17s on mine.
by Cliff » Wed Apr 30, 2025 5:34 am
Hi there
Yes, I did go ahead and change them.
In the end I bought Wolfrace Wheels Assassin Alloy Wheel 17x7 Inch ET42 5x110 and paired them with 215 40 17” tyres. They worked out great, no regrets.
Hope that helps.
Andrew
by JcSE6 » Wed Apr 30, 2025 7:16 am
Thanks Andrew.
Helps a great deal haha. Looks like these wheels should push out about 2mm more than what you've got, which should be nothing to worry about I hope, even with the 30mm lowering I want to do at a later date.
Appreciate the info!
Jack
