Front Splits
Front Splits
Hey guys, Just after a bit of advice on this one.
With the front door with the split set up its got in there, the speaker and the tweeter what would you guys recommend replacing them with? my passenger side ones aren't the best performing any-more and showing signs of ware and tear.
My head unit is a sony cant remember model number ill check it later.
But, I currently got a AS-5100 PowerVow 5-channel Amplifier (1 x 1500w, 4x 350w channel) powering my 10" sub and 2 x 450w max 6x9" Boss BA692 4way speakers
When I get home from work I will update with more details. But any current advice would be great
Note: updated details as i am now home!
zeebie
Re: Front Splits
In mine i have recently put 2 infinity door speakers, 2 infinity tweeters, i put them in at first and the sound quality was shocking, and then added crossovers and wow, what a difference! So i would definately recommend some cross overs
Re: Front Splits
Thanks for the quick reply and advice, Ill keep that in mind
only an hour left till i knock of work
zeebie
Re: Front Splits
most companies produce trhee of four ranges of equipment. go for the second best with any of them. you tend to get alot more for your pound. the very best of kit comes with a massive price tag but you can get a very good quality set up from the slightly cheaper components.
think: vibe space*, pioneer TS-Q,fusion EN-CM etc
breake
Re: Front Splits
I'm looking at replacing the Front Door Speakers...
Are the Original Speaker Mounts, discarded when the Speaker is replaced?
Or are the mounts removed, and then fitted onto the New Speaker???
Re: Front Splits
I used all Hertz's in mine and I'm please with the end resualt.
As For the mounts, I think they were reused.
Re: Front Splits
It's all one piece, remove speaker and promptly discard all into the bin
I made up some mdf spacers from 18mm that extended further into the door card that the crossover mounted to
With the tweeter I removed the standard one and re-used the mount for the new ones.
Some creativity with a dremel and hot glue was required to get them mounted correctly
1995 Orange 16v Ecotec
Mods are coming along nicely
Re: Front Splits
Replaced the Blown Speakers today...
Discovered that the Vectra front speakers, are exactly the same as Calibra front speakers!
So that worked out well for Me...
Re: Front Splits
ive got these pioneers in my astra they sound brilliant.theses speakers do fit calibras.
http://caraudiosecurity.com/shop/produc ... /8642.html
